SeedCode’s products are designed to be modified and we believe it’s important for folks to get in there, get their hands dirty, and make changes themselves. This way you truly own the code and aren’t afraid to modify it in the future.
If you’re a hands-on person, buying the product and diving in may be all you need. Otherwise, you can purchase an implementation package for help, coaching, or having SeedCode do integration and mods for you.
It all starts with purchasing a block of time. You can use that for anything from coaching to development: whatever you need to get up and running, and to make the most of your FileMaker solution…
  • migrating your data from older solutions
  • troubleshooting the integration of SeedCode into your file
  • brainstorming
  • needs analysis
  • customizations
  • coaching (helping you learn to customize SeedCode)
Packages come in five, ten, or twenty hour blocks at $220/hr USD.
With an implementation package you can get in there and make changes knowing we’ve got your back, and that you’ll get deployed on time. (If your project is time-sensitive, please give us a ring as we can’t always schedule implementations immediately.)
Purchase an Implementation Package
Still not sure if a package would work for you? Take a closer look at what it’s like working with us.
DOWNLOAD
DayBack Calendar
DayBack's 30-day trial is unlocked so you can customize it and integrate it with your files.
Download DayBack and we'll send you a couple short emails with tips on how to modify it and use some of the coolest features.
Thank you! Please download: DayBack Calendar
Need More?
SeedCode tips & example files in your inbox
Need More?
Want More?
Be the first to see articles and tips like these
DOWNLOAD
TimeZync
Download TimeZync and we'll send you a couple short emails with tips syncing your FileMaker Go files.
Thank you! Please download: TimeZync
Want More?
